New! Dark mode!
(Topic ID: 240340)
Wrong solenoids firing
By flappybob123
1 year ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by dasvis
#1 1 year ago
Here is the PROPER list of solenoid test #'s for my Bally power play:
1: Outhole Kicker
2: Knocker
3: Tophole Saucer
4: Post down
5: Chime 10
6: Chime 100
7: Chime 1000
8: Chime Extra
9: Left Thumper Bumper
10: Right Thumper Bumper
11: Bottom Thumper Bumper
12: Left Drop Target
13: Right Drop Target
14: Left Slingshot
15: Right Slingshot
16: Post up
17: Coin lockout door
18: Flipper Enable
I ran the solenoid test mode and here are the results:
1: Right Drop Target (x)
2: Right Slingshot (x)
3: Nothing happened (x)
4: Left Thumper Bumper (x)
5: Right Thumper Bumper (x)
6: Bottom Thumper Bumper (x)
7: Left Slingshot (x)
8: Left Target Reset (x)
14: Left Slingshot
15: Right Slingshot
16: Nothing happened (x)
17: Nothing Happened (x)
18: Flipper Enable
I placed an (x) next to the solenoids that fired incorrectly. This problem used to only happen occasionally, and would suddenly dissappear and the machine would work for awhile. But eventually, the issue persisted and has not gone away, even after replacing all header pins, as well as several other components on the MPU board and solenoid board to try and fix the problem. I have already replaced and resoldered all of the header pins on both the MPU board and the Solenoid board, including both J4 connectors. I even used a multimeter to make sure solder joints stayed separated from one another. Help would be appreciated, as I am stumped at this point.
#2 1 year ago
Is this an original Bally MPU and Power Driver board?
#3 1 year ago
I'm not much for the electronics but I do look at data patterns all day.
Perhaps if you list what switch triggers what solenoid it would help diagnose.
I had a similar issue way back. I found a snippet in Clay's guides that might help: (much electronics prattle)
https://pinside.com/pinball/forum/topic/tech-bally-star-trek-coil-mayhem
My solution was just to reseat J4 but you're way past that.
faz
#4 1 year ago
Its likely a connector issue with data lines between mpu and sol driver board . Check j4 connector on mpu and j4 on sol driver board these connectors will probably needed re-pinned .I had same issue on paragon re-pinning theses connectors solved problem
#5 1 year ago
Quoted from pintime:
+1 re-pin Male & females. Been there, done that
nvram.weebly.com
Displays
PinballSolutions.eu
$ 149.95
Allteksystems
Third Coast Pinball
$ 159.00
2,000
Blaine, TN
$ 119.95
Allteksystems
1,800
Blaine, TN
Third Coast Pinball
$ 149.00
$ 49.99
PinballElectronics.com
$ 9.00
Cabinet Parts
Third Coast Pinball
