(Topic ID: 298493)
WPT - Finding Replacement SM Resistor
By killerrobots
67 days ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 65 days ago by killerrobots
#1 67 days ago
I recently got a WPT in a trade and it has a couple of issues I am working. One I think I have figured out but wanted to double check my logic and get help sourcing a small resistor.
I am missing an entire column of lights (IC-U15)
and after tracing the wires found that one of the light sockets was broken and dangling loose behind the back board of the playfield and could have easily shorted (I replaced it). I then measured the U15 transistor and it measured weird so I bought a new one. However after reinstalling it still didn't work. I then started checking other items and found one of the tiny resistors connected to U15 wasn't registering (0 ohms) but the similar one on U17 was measuring 47 ohms. So I think I have a bad resistor but wanted to double check my logic.
However, I can't for the life of me find a replacement. I know the part number and looked on Digikey, Great Plains, google and some other places and can't seem to locate one. Can someone help me source this?
Also, one smaller issue I am curious about. I am getting a service error to check switch 1 and 2 but in they manual they are listed as unused? I am just wondering if this is indicative of some other kind of fault or just buggy code.
#2 67 days ago
Replacement = Vishay RCG080547R0JNEA
Size 0805, 47 ohm, 5%
Other manufacturers available such as Panasonic, Yageo, Bourns...
Can find these at Mouser.
#3 67 days ago
Quoted from G-P-E:
Awesome, thanks so much. I find buying electronics confusing.
#4 66 days ago
Quoted from killerrobots:
I am getting a service error to check switch 1 and 2 but in the manual they are listed as unused? I am just wondering if this is indicative of some other kind of fault or just buggy code.
Most likely outdated game code.
#5 66 days ago
Quoted from Shogun00:
Great...how do I update the code? I think it has a USB, where do I find the newest code?
#6 66 days ago
Just go to Sternpinball.com, click on Support, and then click on the Game Code tab.
Game code updates are available for all SAM and SPIKE tables there. All update are applied via UBS drive.
#7 65 days ago
So I replaced my resistor and transistor and it still didn't work. I am going to try to trace everything through but maybe someone has an idea where to start. I am not an expert but here is what I think I know:
1.I am missing an entire lamp column
2. A lamp socket was broken and dangling and I think very likely shorted (now replaced)
3. When I measure the Y/O pin on the board for AC voltage it measures different than the other pins when in "All Lamp" test mode (So I am pretty confident it is on the board
4. The resistor measured 0 ohm but now measures 47 ohms like the others
5. The transistor did measure weird but is now new and measures the same (however I am not very confident on checking transistors, I am using the diode setting on the multimeter)
The resistor is very tiny and surface mounted and I think I did it right but it is possible it is not so I will check that again as well.
All that I can think of is to measure everything through the board and look for something weird but if anyone had some guidance I would be helpful.
#8 65 days ago
I am going to repost this with a better title
