Something is off with the cut the cards shot. Any shot with velocity comes right back out. If it's going slow it will sometimes go in. How do you adjust that one way gate? How difficult is it to get to? Looks difficult. Thanks.
Mine is like that too. I haven't tried adjusting it. I wonder what the solution is. Maybe they're all like this.
It's so annoying. I get so pissed because that shot is how you set up huge triple jackpots when completing hands and also extra ball and lock. It's such a critical shot and it's hard enough to hit it and then I get so frustrated when it just pops out.
I just bought this and this issue is super annoying. The shot is hard enough to hit as is.
I'll figure something out in the next little while and post it. Everything has a fix.
I've adjusted mine. I pulled the one-way gate out a little bit and haven't experienced any problems since. Easy does it...better to go too slow and need to do more than to go too hard and can't reverse it.
I tried that, but one end popped out. I had to take the whole mech out from behind.... wooooaaaazers! That mini and backboard are some of the hardest shit to deal with in pinball!
I took the very interesting and different mech out, cleaned it up, and figured out how to make this work. There is a little flap above the gate that springs the gate back down as fast as possible. I took the gate off, best this flap down to give added power to the gate firing back to block the balls from popping out, then installed the gate and bent it down more. Played with it while, and after, it worked perfectly.
I replaced the blue lights with blue LEDS for the pops, interesting how that acts like a lane changer, neat idea. After, everything was done, and my back was f'ed, it all worked perfectly.
I took out the rear left gate too allowing right orbit shots, I like it much better like that.
