Does anyone know what component U27 should be on a WPC95 Part Number 5764-14553-09 MPU board? In the normal WPC-95 schematic, U27 would normally be a 74LS02. But on this revision board, there is no way it can be a 7402 (Outputs are grounded, inputs go to drive other ICs etc.).
I am working on an acid damaged board out of a Tales of the Arabian Nights. Someone had already pulled U5 and U27 and then gave up. I am pretty sure I have the board repaired but need to figure out what goes in U27 (source of Driver Board Data Buffer Enable signal).
I have found a few reference to 3 different versions of the board and a couple of photos of a -09 but none are clear enough to determine the correct IC for U27. The Date code on this board is 22-96
Any Help would be greatly appreciated.
I have attached an image. Traces around U27 are drastically different than the normal WPC95.
