(Topic ID: 318393)
WPC95 Reset and bad opto?
By dgposter
8 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 8 months ago by dgposter
#1 8 months ago
I turned on my NGG yesterday and after 20+ years I'm having my first problem with it. As soon as the game fires up, the Putting Green solenoid (Clubhouse Kicker) activates about 6 times then stops. I tested the optos and they are not working for this device (they were fine last time I played). I've followed the guides and checked connections, boards, etc. but everything "looks" ok.
Also, the game now resets while playing and I narrowed it down to the left orbit switch. Whenever I hit this particular switch the game will reset. I replaced the diode but the problem still exists. If the switch is unplugged I have no reset problem.
Do you think these 2 issues that started at the same time are related or is it just a coincidence?
Is it possible that the actual orbit "switch" could be bad and cause a reset?
Any advice would be appreciated.
Edit: I just put it in test mode and when I hit the left orbit switch it triggers 2 things. Before triggering the switch, it very quickly registers a "slam tilt". I see this message go by fast and there are 2 audible beeps as if I am testing 2 items.
Edit2: The Sand Trap "Adv Trap" standup target is registering both the Right Outlane and the Adv Trap target in switch test mode.
#2 8 months ago
So your game is not resetting. It is slam-tilting.
And it is doing this because you have a switch matrix issue on the PF.
Make a "map" of the switches involved using the switch matrix diagram.
That will help isolate the switch with a failed diode or a connection that is not correct.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
https://www.youtube.com/c/ChrisHiblerPinball
#3 8 months ago
Thanks, Chris.
I will do that and post back the results.
$ 29.99
Pinball Shark
Shooter rods
Professor Pinball
Interactive
$ 105.00
Arcade Upkeep
Other
$ 399.95
Pin Stadium Pinball Mods
Led
Long Beach, CA
$ 54.99
Shooter rods
$ 89.99
Led
5,400 (OBO)
Wyoming, MN
This page was printed from https://pinside.com/pinball/forum/topic/wpc95-reset-and-bad-opto and we tried optimising it for printing. Some page elements may have been deliberately hidden.
