hello to everyone , I have this WPC95 MPU that as soon as the power goes through the machine, energizes the right lower flipper.
The coil remains stuck on until power is removed either by opening the coindoor or shutting down the pin. The solenoid goes stuck on even in test menu, it is not necessary to start a game.
I am pretty sure the problem is on the MPU and not elswhere (ex. a shorting transistor on PDB) because the problem moves through the machines swapping MPU boards..
I have consulted the schematics and think that the problem is in the yellow area(attached image), maybe some failed component let the MPU "think" that the related LR Flipper switch is pressed and activates the coil? Is it possible ? I'm not really sure how to narrow down to the culprit component, I have tested resistors with dmm and they are ok, note that all the lm339 and other ic on the board had been replaced and socketed except the U25 and U7 on this circuit!
Any advice on what to do now? I'd rather don't shotgun replace parts...
Please feel free to correct me if you think i'm on the wrong track!
thanks in advance for your precious help!
