(Topic ID: 317488)
WPC95 failing 5v voltage regulator
By ndz
9 months ago
  • 45 posts
  • 11 Pinsiders participating
  • Latest reply 7 months ago by Tuukka
#1 9 months ago
WPC95 Scared Stiff wouldn't boot (no 5 volts at driver board or MPU) and was blowing fuse 105.
I assumed a failed bridge rectifier so I replaced the usual suspects.
D7, D8, D9, D10
Capacitor C9.
Still no 5v at driver board. Fuse 105 no longer blows.
I replaced Q1 (LM317k) voltage regulator. Checked all paths and througholes to the best of my ability.
Powered the game up and get one 'bong' then 5 volts goes out on the driver board.
I replaced Q1 voltage regulator again. Powered up with MPU disconnected. 5v is now present. Voltages at MPU connector are correct.
Connected the MPU at J101 and the ribbon cable. Powered up and again one 'bong' and then lost 5v at the driver board again.
Replaced Q1 (third time) and powered up and I have 5 volts again at the driver. I haven't hooked the MPU up again as I expect the same to happen.
What can I check to prevent another Q1 voltage regulator failure before hooking the MPU up again? The connectors and cables test fine. Could there be an issue or short at the MPU causing Q1 to fail on the driver board? Do I need to power up the MPU on the bench or what would be the next step? Thanks!
#2 9 months ago
The regulator should be short-circuit protected, so not burn out very easily. Have you bought the regulators from a reliable source, there are lots of counterfeit LM323's around and maybe also LM317K?
Powering up the MPU on the bench will enable you to measure current consumption, should be about 0.3 - 0.5 amps from the 5V line.
#3 9 months ago
Quoted from Tuukka:
Thanks. The first LM317k replacement was from Marco. Next I bought at 10-pack from Amazon.... But it would be a coincidence if they were bad from both sources. I figured the next step was to either draw 5v from the driver board or put the MPU on the bench. I'll work on it. Any additional suggestions would be appreciated!
#4 9 months ago
Check that your CPU board or connector does not have a short between +5 and +12V, the regulator is usually quite robust but does not tolerate external higher voltages at output.
#5 9 months ago
Quoted from Tuukka:
Yes, I checked the connector and MPU J210 pins and found no shorts. Maybe it's upstream on the MPU.
I'll try to get the MPU on the bench. Thank you!
#6 9 months ago
Yeah, i would not be surprised of counterfeits.
This is the best replacement for the WPC driver board. https://www.ezsbc.com/product/psu5-nonoise
Unfortunately, I don't see a LM317k replacement for the WPC95 driver board on this website.
1 month later
#7 8 months ago
I ruled out the MPU by swapping it with another game. (unless could there be an issue with the game rom or security chip? Seems unlikely)
Same story. MPU starts to boot, I hear one bong, then 5 volts is lost (voltage regulator LM317k on the driver board is toast). This will be the fourth time replacing the voltage regulator to restore 5 volts on the driver board.
Strange problem. It looks like I need to find a way to get the driver board powered up on the bench and draw 5 volts.
#8 8 months ago
Your LM317K's are fake.
Buy a switching regulator like the EZSBC as it is guaranteed to be short circuit protected and won't blow up if you have some board fault.
There are just too many FAKE LM317K around to trust ANY of them these days. Don't waste any more time of money trying them.
Another tip - don't shotgun parts for a repair, it rarely ends well and often introduces additional faults. Troubleshoot LOGICALLY and replace ONLY what is actually causing the fault. After fixing the fault, it is sometimes prudent to replace known troublesome caps etc but please don't do this as if it is normal repair procedure - IT ISN'T!
#9 8 months ago
Is there an LM317K replacement like the EZSBC? I've been unable to find one.
My regulators were from two sources (marco and an amazon seller). I suppose all could be fakes...
Agreed on the shotgunning. To test the usual suspect components, they had to be removed from the board anyway so I just replaced them first (diodes and cap).
#10 8 months ago
I would ditch that LM317 altogether and replace it with the fixed 5V switching regulator EZSBC.
Only mods I can see you would need to do are ground the pin that currently goes to the resistor dividing network (R1 & R2) and rip out those two resistors.
I can't see any reason NOT to make this small mod?
#11 8 months ago
Quoted from pins4u:
It seems a little more involved then that. The data sheet for the LM317K that is used on the WPC-95 power driver board shows that pin 1 is the adjustment, pin 2 is Vin, and the case is Vout. The data sheet for the LM323K that is used on the WPC power driver board shows that pin 1 is Vin, pin 2 is Vout, and the case is ground. If we assume that the PSU5 has an identical pinout to the LM323K, then mods need to be done to isolate all pins and the case and then jumpers need to be run to make all of the appropriate connections.
(started documenting required mods, but deleted it)
Doing a bit more research shows that somebody has already documented how to make the PSU5 work in a WPC-95 machine. Please have a look at:
https://pinside.com/pinball/forum/topic/installing-an-ezsbc-psu5-into-a-wpc-95-power-driver-board
I would personally make all of the cuts as close to Q1 as possible, rather than far away as shown in the above link. This should allow for much shorter and cleaner jumpers to be used. At the end of the day, though, as long as Q1 is fully isolated and connected appropriately using decently thick jumpers, it will not matter.
#12 8 months ago
Quoted from ndz:
Not a switching regulator like the EZSBC but ... NTE970 is a valid replacement.
Not cheap but I believe NTE still actually manufacture the part. Fakes are not re-labeled as NTE. Available from various merchants and from NTE via the Digikey marketplace.
#13 8 months ago
Thanks all for the suggestions. I ordered up a few NTE970's and will report back.
#14 7 months ago
She's ALIVE!!!
NTE970 bought from ebay did the trick. Go figure, the LM317K's from marco and amazon were all rubbish.
Thank you all, especially Dumbass for the tip on the NTE970's!!!!
#15 7 months ago
Quoted from ndz:
She's ALIVE!!!
May I ask which eBay user you bought these from?
#16 7 months ago
Quoted from ndz:
She's ALIVE!!!
Are you going to contact Marco and Amazon to let them know they are selling fakes and get a refund? I doubt Amazon will do anything more than refund you, but hopefully Marco will remove these bogus parts from their inventory and source genuine parts of the NTE equivalent that you used. It would be a shame to see another owner jump through the same hoops that you did!
#17 7 months ago
It was a one-off 3 pack from a seller who doesn't appear to have any more. I bought the ones in the NTE bag.
I'll reach out to amz and marco. Thanks again.
#18 7 months ago
Post a picture of them please -- would love to see the manufacturer and dates on them.
#19 7 months ago
Sure. Sorry for the large pic.
BTW, Marco replied immedately, offered refund, and said they have had issues with these before and will alert their procurement dept.
The amazon seller "laptop-part" replied with "could have been damaged in transit" "we have sold lots w/o problem" and referred me to amazon corporate to ask for refund
#20 7 months ago
52nd week of 2004 date code - the production date is proper for National Semiconductor.
Part marking is correct for that time frame (note "-MIL" does NOT mean Military). Military parts either have the military part number or have a "/883" suffix signifying they have been screened to Mil-Std-883. Usually the Military grade of these would be "LM117K/883" where the LM117K is the extended temperature version of the LM317K.
Part marking on your part looks like shit but I have seen genuine National parts look like shit. Can you remove the lettering using acetone (fingernail polish remover)? If it comes off easily, it's fake.
Noted bad thing for your LM317K, that date code of 0452 is on every National Semi LM317K part listed on Amazon (and many on ebay). And the marking orientation is also all over the place - some vertical and some horizontal. That is not a good sign. A semiconductor manufacturer always picks either vertical marking (as shown by yours) or horizontal marking. They do not switch back and forth in the same batch.
NTEs are pretty much the way to go for these. Note that NTE does NOT make parts but are packagers. They buy residual die's from manufacturers and package the parts themselves. Even NTE parts are counterfeited from time to time so be careful who you buy them from as well. If the NTE parts ever do dry up and you're desperate for a new regulator -- Texas Instruments still makes these National Semiconductor parts. Only downside is they're about $60 each. ouch!
#21 7 months ago
Maybe removing the case top with a hacksaw from the original part and one of the suspect counterfeits could reveal difference in die size.
#22 7 months ago
Just checked my latest batch of spare LM323K's from eBay. All have date code 0452, and all the markings could be wiped off with some contact spray. Bummer!
#23 7 months ago
I wouldn't be surprised if you find a weenie 15 cent TO92 of some cheap brand of LM317 inside the metal can.
https://lcsc.com/product-detail/Linear-Voltage-Regulators-LDO_UMW-Youtai-Semiconductor-Co-Ltd-LM317G_C347367.html
Some of the fake LM323K seem to go into shutdown mode around right around 1a. People have used them in a bally game successfully until they add LED displays or something. Probably jam the jelly bean dirt cheap TO220 die version inside those and its not well thermally bonded...
Don't buy active parts like this from Amazon and saddly it seems like Marco too. Authorized distributors only, if you are trying to save some money, check LCSC they have asian brands of some things that have a datasheet will at least not be a counterfeit of a western brand.
The metal can voltage regulators and power transistors are like 90% fake on amazon...
#24 7 months ago
Quoted from barakandl:
And yes, we have seen the 2N2222 or something like that in a TO-3 cased 2N3055. And also the 10000 uF electrolytics, with a Chinese brand 1000 uF inside the can.
I guess I will make a test bench for my LM323s, run them for an hour properly heat sinked at 2A and 10V input, making 10W power dissipation - about the worst case in WPC driver boards.
Fortunately I have not installed those eBay regulators in any of my friends boards yet.
#25 7 months ago
I checked a couple of them and was able to scrape the numbers off with my finger nail somewhat easily. I guess that confirms!
#26 7 months ago
Quoted from Tuukka:
Fortunately I have not installed those eBay regulators in any of my friends boards yet.[quoted image]
Is it the picture, or is the lid on that part very off-centered? I don't see any kind of tolerance shown in the mechanical drawing in the data sheet for the LM323K for that, but I would expect a true National Semi device to be more centered than what is shown in that picture.
#27 7 months ago
Yes, the lid is off centered in random direction in nearly all of the 10 pcs I have.
And what's even worse, the parts are either faulty, or are not LM323's. I will test them again as LM317's, because they look exactly like OP's fake LM317K. Maybe I will open one and try to look at the die with microscope, if there are any markings.
#28 7 months ago
Quoted from Tuukka:
There won't be any markings on the die but its size will quickly give the game away.
#29 7 months ago
Does not look like a 3 amp die or bonding wires to me.
#30 7 months ago
Quoted from Tuukka:
Does not look like a 3 amp die to me.[quoted image]
The wires might struggle at 3A?
You would have to chop a known 'real' one to know for certain. The dies can be a lot smaller than you might think for some parts.
#31 7 months ago
I might have one failed original part in my gameroom trash bin. Will open that when I get there.
So here. A Linear Technology dated 1992. The die size is not so much larger than the fake one, but there a two pairs of heavier bonding wires, going to different places on die, probably to minimize hotspots. Or there might be two output transistors in parallel.
#32 7 months ago
Neat. Thanks for cutting open an original. Never would have guessed those wires would be so thin on a power part.
#33 7 months ago
Nice job! Notice there is a LOT more metal that the die sits on than in the fake. Each of those connecting wires could easily handle 5+ amps so they are certainly adequate for this part.
#37 7 months ago
The first part shown cut open in this thread is an LM317, correct?
And the second part cut open is an LM323K, right?
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
#38 7 months ago
The cut open parts and cases I posted are both LM323K's, first the fake then the original. The first picture by OP is his LM317 case.
#40 7 months ago
I've always wondered what the inside of that part looks like. Thanks for posting the photos.
#41 7 months ago
My fake parts do not work as LM323, but not as LM317 either. I don't know what the die actually is.
#42 7 months ago
Quoted from Tuukka:
Most likely something super common and cheap like a 2N3055?
If you have one of those cheapo component testers it might find it?
#43 7 months ago
Quoted from pins4u:
Now that's a good idea!
Clearly, not a transistor either.
A working original LM323 connected to tester in same way resulted in "No, unknown or damaged part".
#44 7 months ago
hefty hefty hefty, wimpy wimp wimpy.
The wires are short enough, but the real part has two bonding wires for each, and they look at least 2x as thick. The fake ones are probably hack job in China using the cheapest 7805 die possible. With a resistive load the fake one start to choke out right at 1a.
Hard to say what the totally fake stuff is. There is a couple chips on the SB300 that are quite obsolete i have to scrounge up. I saw one of them appear on AliE for pretty cheap so I took a chance on it. The chips are for sure a new produced item as the bottom side case imprints counted logically in the tubes A1, A2, A3 or whatever, all chips same perfect new plastic chip package. Funny looking logo to half imitate TI. There was active circuitry inside the chips and legs that where supposed to be connected to something are , power pins where at the right corners, but it did not work. I honestly think it was some screw up parts and they decided to try and sell them anyways. I have seen that dodgy looking TI logo before on functional jellybean stuff.
The fake switching regulators use on the cheap LM2596 modules seem to operate at slower frequency.
#45 7 months ago
The component tester identified some of my 7805's as Darlington transistors with high Vf of about 3V. Some 7805 were identified exactly like the fake LM323, with normal diode between output and ground, and a high drop diode lookalike.
So it is very possible that the fake LM323's were made using 7805 die, but something went wrong, because they take almost 60 mA input current with output unconnected, and voltage at output is under a volt. I had 0.1 uF caps to ground at input and output so it was not oscillating. Just for fun, I might try testing all 10 pcs, but into trash they go even if some would imitate a 7805!
Edit: All tested. Two out of 10 were completely open (missing/broken bonding wires or forgot to install die?). The rest 8 were all alike. With 8V input, quiescent current was 60 mA and output 0,45V.
I tried swapping the input and output, just in case the faker had cross-connected bonding wires. Then I tried the negative voltage regulator pinout and connection. No luck.
Be careful what you buy, especially if it is an obsoleted component. With the LM323/LM317 regulators, especially watch out for the NS logo and 0452 manufacturing date.
"Sometimes you get more than you bargained for. Beware of unusual parts... in the Twilight Zone!"
£ 39.00
$ 29.99
Pinball Shark
Shooter rods
10,000
Orlando, FL
9,000
Lake Elsinore, CA
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/wpc95-failing-5v-voltage-regulator and we tried optimising it for printing. Some page elements may have been deliberately hidden.
