Where are you putting the strip?
If it's not near the backbox, 12v is really easy to access off the small cabinet interface board near the coindoor.
Haven't worked with 12v off the backbox boards.
Quoted from RCA1:Where are you putting the strip?
Lighting up my volcano on Congo
Ok, check this out. I repinned the connector off the flipper opto board to feed off the 12 volts. When its plugged in I get no light. I unplug it and they work.
Is the feed too much of a draw for that board?
How did you feed your led strip?
Thanks again for your help
20200404_200927 (resized).jpg20200404_200958 (resized).jpg20200404_201024 (resized).jpgI didn't connect at the opto board.
I used pins 1 and 2 on connector J2 on the interface board mounted below the opto board.
Pin1 is ground and pin 2 is +12 v.
I think that 12v is there for a bill validator.
See pages 3-22 and 3-23 in the manual.
Quoted from RCA1:I didn't connect at the opto board.
Thank you!
Worked perfect. Thank you.
20200405_121122 (resized).jpg20200405_123524 (resized).jpg20200405_155841 (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/wpc95-12-volt-led-strip and we tried optimising it for printing. Some page elements may have been deliberately hidden.
