(Topic ID: 16390)
WPC & WPC-95 game Help
By Loupie
11 years ago
    #1 11 years ago
    1. Factory Settings Restored (T2) - I replaced the batteries and still have this problem
    2. Switch #36 Catapult (FT); in test report, I can't clear, but catapult works fine.
    3. Lt gate stuck (AFM); in test report, I can't clear, but the lt gate works fine
    Any ideas how to clear these problems pls. Thanks!
    #2 11 years ago
    Quoted from Loupie:
    #1: battery holder is either loose or corroded causing it to no longer make contact. Or your batteries are in wrong. Test with a dmm.
    For other errors, use switch test to clear them. The CPU only knows about switches so all errors come from switches that are either stuck or don't trigger.
    #3 11 years ago
    You'll have to check with a meter if battery power is getting onto the CPU, the pads holding the battery may be bad.
    Go to single switch test and stop on the switch with the error and hit the start button.
    Otherwise you may have to do a factory reset to clear the errors. You will lose high scores and adjustments doing this.
    LTG
    #4 11 years ago
    The catapult will still work on FT even if the switch doesn't work, because the game knows the switch isn't working. My buddy had this problem, and although the catapult did fire it took a little longer than normal. Replace or fix the switch.
    #5 11 years ago
    Quoted from Loupie:
    Must be something in the air - my TAF did that to me today when I powered it up for a game, reset things, powered down and up a couple times and all is good. Hopefully a badly seated battery just got vibrated, if it happens again will dig in and see whats up.
    This page was printed from https://pinside.com/pinball/forum/topic/wpc-wpc-95-game-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
