The +5 comes on the rectangular one, not the cube one.
Yes, I'd say the 4.65 is too low and is causing the reset.
The LM323 can be involved here. I just had one that was good at initial powerup, like 5.01, but after running for a 6 hour burn in test, it dropped to 4.91. J101 was tarnished, so I replaced it. Pulled C4 and C5, tested them with my cap tester, out of spec, replaced them with new parts that I tested first and were OK, fired it up, and my initial 5.01 had dropped to... 4.88!
Replaced the LM323 and now, it's good. Comes up at 5.01, and after a 4 hour burn in, still at 5.01. I'm content with that. Gonna let it go another 2 hours on the burn-in and check voltages again. This one is going on route, so it's important that it's rock solid.
From my experience, a bridge is good or bad - no such thing as marginal. It's just 4 diodes. Either it tests good, or it tests bad.
On your game, here's what I'd do
1) Replace the female plug that connects to J101 and retest voltages
2) If voltages are off, verify traces to/from J101, BR2, LM323, C4 and C5. Don't pull parts, just put your meter on continuity test, bust out your schematic, and verify everything is connected where it should be. Maybe reflow the solder points on them.
3) Test again. If still no bueno, inspect C4 and C5. Are they bulging at the ends? I've found that caps are RARELY the problem, and you stand a pretty good chance at damaging plated through holes swapping them out.
Unfortunately, there's no good way to test C4 or C5 without removing them. They don't test real well in circuit. So, even if you had a cap tester, you might not be able to get a good test on them in-circuit. So, if you're going to pull them to test them.. I typically replace them. But, I do a LOT of testing before I remove them.
