Hi
I've got a TAF that I'm trying to wire up a secondary power adapter to, by using unused pins on the female 9 pin connector (per instructions for the unit)
I have discovered when attempting to install this that the female 9 pin plug is wired incorrectly, at least according to the schematics (WPC schematic available here: http://arcarc.xmission.com/Pinball/PDF%20Pinball%20Misc/Williams%20WPC%20Schematic%20manual.pdf)...
(I'm in the UK and the pin was sourced from Europe, so 230 VAC is the correct configuration)
I have established that the male end of the cable, the one connected to the transformer, is wired correctly according to the above schematic.
The female end - connected to the line filter box, however, looks like this:
The two wrong wires I can see are:
- white (plugged into 4 - white/brown on male, should be in 7 - white/orange)
- one end of orange loop (plugged into 6 - brown, should be in 9 - orange)
Now, I know the following:
1. The game works 100% with no issues I can see
2. I have the correct transformer - 5610-12835-00
3. The male plug is wired correctly per the schematic
4. The female plug is wired incorrectly, the white and one of the orange loop wires are in the wrong places)
Does anyone know the voltage configuration of the wires that come off the transformer and can explain why it would work despite being wrong?
Is it safe for me to repin the white and one orange pins to their correct position? (one to the left in both cases) ?
Does my line filter box look right?
Thanks in advance for any help.
19AC3E62-1D9E-4092-9362-70EBA40FC486 (resized).jpegB3A3C2E4-7D31-41FB-89BB-ED6785FF464C (resized).jpeg8FDC19CE-1ED3-4AA2-B221-C3DDBAE3035E (resized).jpegCECB3ABB-563E-4F77-BE3A-07FC5B519C2B (resized).jpegF77EFA15-7439-4AB3-9CED-5F56F67D3B37 (resized).jpegB87919EE-260F-4CF1-96C9-91F2085F6201 (resized).jpeg
