I have a Demo man.
Manual says this game should have a 5610-13953-00 WPC Transformer...it has a 5610-12835-00 (early generation I believe)
Manual says this game should have an A-17540 Power Interface Box .. it has an A-15707 (again I believe early version)
1) Inside my power box is a Thermistor but no Varistor (MOV). Looks like it used to have a MOV but was cut out. In my Demo Man manual I see no Varistor in the A-17540 Power Box. Do I need to install one in this A-15707 and if so anybody have a part # ?
2) I'm trying to re-pin the connectors from my power box to my transformer. I had some crimp connectors from a random bag ( I didn't buy them) which I thought were .093" but once I installed them (3 in pic) in the molex connector they are very loose, don't line up and the force of trying to put the 2 connector ends together actually pushed the wire/crimp back out of the connector. What crimps should I be using?
3) What gauge is the transformer and power box wiring? I thought it was 18ga but I used some and it seems small compared to the original wiring.
4) My wiring was all hacked. Think it was a re-import. What is the correct pin layout (USA 120v) of the wires coming from the transform to the connector that plugs to the power box. Pic below from pinwiki shows 1-9 layout for powerbox side. I labeled them 1-9 left to right in my trans pic. Manual shows the schematic below. I guess i'm just a bit confused as it shows wires being connected from the trans (2 blacks, 2 wht/brn, 2 wht/org). So does this mean I could put wire #1 (my trans pic) into plug position #2 (pinwiki pic) and it wouldn't matter? I don't know if far left blk wire on my trans would be called #1 in schematic essentially.
Any input is greatly appreciated. thanks
2022022795161355 (resized).jpg2022022795161435 (resized).jpg11605 (resized).jpg2022022795165239 (resized).jpg2022022695230008 (resized).jpg2022022695230053 (resized).jpg
