New! Dark mode!
(Topic ID: 276573)
WPC switch matrix oddity
By EStroh
57 days ago
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 56 days ago by EStroh
#1 57 days ago
WPC fliptronics 2 (Black Rose)
In switch edge test I'm getting a strange issue between columns 5 and 2.
If I hit ANY switch in column 5, it not only registers there, but also the corresponding switch in column 2. For example, if I hit the switch at col5 row1, it will register as a contact with BOTH col5 row1 AND col2 row1.
It doesn't happen in reverse (activating a switch in column 2 just registers as expected).
Any ideas? Maybe a bad chip U20? Maybe a switch on col 2 is grounded somewhere?
Probably not related: also happening at this time the cannon immediately fires when a ball is loaded. The switch for the fire button is in column 3, so I'm not sure what's going on here.... but both issues started at the same time. Odd
#2 57 days ago
Post a picture of the MPU.
#3 57 days ago
Quoted from PinballManiac40:
Thanks for your reply.
I can do that tomorrow. What area of the MPU?
I forgot to mention: If I pull the green-wire switch "column" connector off the MPU, I still get an odd reaction. With only the row "orange" connector attached to the MPU -- any switch contact on column 5 actually registers as a column 2 contact. It's like column 2 is permanently activated, but only a contact to column 5 will make it register... but as a column 2 switch. No other switch registers (of course) when I pull the green "column" connector off the board.
#4 57 days ago
Be nice to see the whole board.
#5 57 days ago
I'll take a photo tomorrow, when I'm in front of the machine.
#6 57 days ago
Quoted from EStroh:
Need more info. Old board? Connectors repinned? Possible acid damage/corrosion on MPU or connectors. That is why we ask for pics of the MPU and connectors that plug into the MPU
#7 57 days ago
Also wondering, did you recently repaired any wiring to a switch or replaced a switch?
#8 57 days ago
No acid damage, and the game was playing just fine up to this point. The batteries are about 2 months old.
I replaced a couple switches when I got the game (about 6 months ago). Nothing recent.
I adjusted two ramp switches recently : lockup entry (in column 7) and left ramp enter (column 4). Nothing in the "affected" columns 5 or 2.
One more thing: The "ramp down" switch is showing up as closed (column 5!), and in fact the ramp is up. I'll take a look at that, but I don't see that causing a "bridge" between ALL the switches in column 5 creating duplicate contact closures with those in column 2.
Thanks for the help.
#9 57 days ago
Best thing to do first is go into the switch edge test, unhook J206 and J208 and use a jumper wire to test the switch inputs and to see if you can prove the board is at fault.
#10 57 days ago
That's a good idea. I'll try that.
#11 56 days ago
U16 looks corroded to me.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact
#12 56 days ago
Well the problem now is... it's working.
I'm sure that won't hold true forever, so when that happens I'll look at U16. I think U20 controls the switch columns, so I'll add that to the list as well.
$ 87.95
$ 54.99
$ 54.99
$ 9.99
2,720 (Firm)
San Francisco, CA
$ 19.99
PinballElectronics.com
