Quoted from ripple:Both U14 and U15 image did not match using my Needham's Eprom burner. U18 did check as a good match. I triple checked U14 and tried burning 2 different Eproms and still get the error.
So reading the original U14 and U15 in a writer attached to computer resulted in a mismatched checksum compared to the known good "master" image?
U14 should be $A08A
U15 should be $9588
I assume you did the following:
- Write a new clean image for U14.
- Tried it in the machine.
- Still produced U14 checksum error.
- Removed U14 and verified in the EPROM reader that the checksum still matches.
- (For grins and giggles) Tried it again in the machine to verify the result reproduces.
If you've done that then there's definitely a problem on the board. I'd check all 32 pins of the U14 socket for continuity to the correct point. Almost all of those pins are either the address or data bus and continuous with the same other pin on U15 or U18. It's really only CE/OE (pins 22 and 24) that are specific. It looks like (according to the schematic) that OE (pin 24) is tied together for all the EPROMs.
Specifically U14 is A21 connected to U28-15. If you have (static) continuity then you'll probably need to verify (dynamic) functionality. A logic probe should reveal the signal transmission on this line.
