(Topic ID: 271041)
WPC Sound Board Repair Advice
By SeymorGoldfarbJr
    #1 3 years ago
    This is in regards to my Gilligan's island sound board (A-12738-20003). The back story is the sound was very scratchy when I bought the game. I took the easy route and bought Marco cap kit for it. The board was clearly worked on in the past. I replaced all the caps except for the two large caps as they looked newer. The game sounded better but not great. I then replaced the two larger caps. When I put the board back in the game to test it, I accidentally connected both sound plugs (J504 and J505 ) to the positive output (pin 2 on each connector, J504-2 and J505-2) instead of pin J504-2 and J505-3. Within a few seconds I could smell a chip or component burning and I shut the game off. There is absolutely no sound output from the board now.
    I order a new amp (U1) and replaced that, no change. I swapped out the three sound ROMs (U14, U15, U18) and the three other socketed chips (U10, U11, U13) into a known working board and it still worked perfect, so I know those components all are good along with the speakers in my game.
    The R20 resistor looks like it got pretty warm. It measures around 2.5 Ohms. It should be a 1 Ohm resistor. I have not replaced this yet as I don't have the correct resistor in stock.
    I'm looking for suggestions on what components I likely damaged which I should check or replace?
    #2 3 years ago
    You might want to check U3 the -12v Voltage regulator and also U4 12v Regulator.
    #3 3 years ago
    Also check R23 and R24, in case the board came from a different game.
    #4 3 years ago
    Is there a rebuild kit for WPC sound boards that I can purchase?
    #5 3 years ago
    Quoted from whthrs166:
    I measured at the voltage regulators:
    7812 - 26VDC in, 12 VDC out
    7912 - 0.4VDC in, 0.6 VDC out
    Does that indicate the 7912 is bad, or that I lost voltage somewhere before the regulator?
    #6 3 years ago
    Those voltages don’t sound right. Check the schematic I don’t remember what you should see there.
    #7 3 years ago
    I figured it out. The top side trace on C24 did not have continuity to the negative side of the cap. I fixed that and the sound board works again. Unfortunately, the static in the sound persists.
    This page was printed from https://pinside.com/pinball/forum/topic/wpc-sound-board-repair-advice-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
