Gang:
Scared Stiff recently started registering false opto closures.
It is sporadic and across what seems to be all (or at least, most) of the optos. All of a sudden, you will get credit for hitting a ramp, or a locked ball, or entering the crate.
Every once in a while you can play a game without issue, other times the false closures start immediately with Ball 1.
I have repinned the .156 connector on the 16 opto board under the playfield and confirmed that I was getting proper voltage there. When that didn't resolve the issue, I replaced the 16 opto board with a new one from DumbAss . Still no resolution.
So, it does not appear to be any one opto in particular, or a trough or a 16 opto board issue. I have not repinned the .100 connectors on the board, but they look good.
Again, the game was working 100% and was not moved or the target of an "event" which would provide a clue.
Any input is appreciated - thank you!
