5/31/16 update **blew the 2030. Replaced. Cab side works fine. Something is still funky with the backbox side of the board. Amp blows at volumes above 15.
2030 replaced on Popeye but still not working. The journey continues****
I was working on diagnosing why only my cab speaker was working on my JM. Whole other issue...
So i go to swap the sound board from the popeye to the johnny to see if it was the board and not the speakers. It seems it was. So, I go to put the board back in the Popeye and turned it on. Seemed fine but then the audio started to crackle then the amp (transistor? TDA2030AV) started to smoke....... I quickly turned it off.
LIKE A FREAKING IDIOT I look around to see what is messed up. I see its the amp so......I put the Johnny board into popeye......( I know I deserve what I get) I turn it on and I here a pop, QUICKLY I turned the machine off. And as can imagine not only did I have the issue with my backbox speakers but now the Johnny board's amp (I assume) is blown.
So I check voltages on Popeye. I need to do them again but it seems like the sound AC is 20V (should be 18). The pnes on Johnny seem fine. Just trying to figure out what I blew. I think....based off the manual it may be the transformer........agggggg b/c it says the 18v AC comes from there......COULD be wrong, I didn't have a lot of time this morning so I just did some surface checks and tests.
SO I will be testing more to see where I went wrong (and if anyone has a suggestion why the cab speakers worked and the DMD ones didn't in Johnny....but I am not too concerned with that)
I know I will need new TDA2030AV, what else do I need to check...OBVIOUSLY there is something messed up with the power otherwise the other sound boards amp would not have blown.
Open to suggestions and criticism.
