Scratching my head over this one and running out of things to check/test/repair.
Globally, the HP solenoids on a BSD appear weak. The shooter lane barely gets the ball into the upper PF. The Pops seem a bit weak although still bounce the ball around.
What I've done/checked:
BR3 was replaced
C8 100uf cap was replaced
All traces/pads verified with good continuity
TP measures 70VDC unloaded. No AC Ripple on DC signal.
Shooter coil (the one I'm using for tests) measures 70VDC unloaded to ground, 50VDC when firing
Headers J101, 102 and 103 replaced for incoming AC
Plugs at transformer reseated and inspected
Connectors for Grounds on Aux Board for Solenoids reseated
J107 power to coils reseated (Have not replaced this header, however)
Good Screws to Aux Board to Backboard for grounding
Strength seems no different whether coming from transistor on board or if I ground the coil lug directly (tested using ground jumper from cabinet directly to coil)
Diode for this coil on Aux board tests fine
In that there is no difference in strength from a direct ground to board ground, would tell me that it's a power side problem, agree?
