shadow game started up with ground row short on rows 1-8. check j206 j207 no short to ground so changed the u20 chip on cpu fixed the ground row short errors but now j206 j207 row 1,2 and 5 not working. checked the cpu with logic probe (first time using one)no pulse at j206 j207 pins 1,2 and 5 then checked u20 chip pin 1,2 and 5 on the input side all read low and output side 1,2 and 5 high evrthing else is pulsing. where does the signal come from for the u20 input side? what should i check next? hard to find info on this board evrthing seems to be for wpc-89
