If you're going to play it anyway, you might as well try some one-minute quick fix workarounds.
Reseating J114 (WPC-95: J105) on the power driver board, J210 on the CPU board, and a Z-connector in between (if your game has one) will help temporarily if those connectors are the problem (which wouldn't be too surprising). Those are the connectors that carry 5V from the power driver board to the CPU board. If this temporarily fixes the problem, it will only be temporary, it will come back, and replacing those connectors will eventually be required.
Of course, before reseating those connectors, it'd be better to measure 5V on the power driver board (TP2) and on the CPU board (see Pinwiki section 4.13.10). You can quickly determine if those connectors actually are part of the problem, and if you reseat them one at a time and then measure voltages, you can find out for sure which one is the problem.
