I picked up a Hurricane over the weekend that is having the classic WPC reset issues once I reconnected the Ferris wheel. For those of you who don't know how the Ferris wheel works, it is switched on/off by a 12v relay on the board, and it is powered off the 50v AC power through plug J104/105 on the power supply board. In test mode, and game mode, when the Ferris wheel runs more than about 10 seconds, the game resets. The game seems to run fine when the flippers are activated.
The 5v power supply looks to be pretty borderline. When I measure the voltage at the + terminal of BR2, I am only getting 5 volts DC. According to pinwiki, this should be at least 9 volts. The associated cap looks pretty good as I am only seeing about a 100mv AC RMS (measured with a good fluke) at the same +terminal of BR2. At the test point on the power/driver board, I get 4.85 to 4.90 volts. My 12 volt line is running high at 14.5 volts. Should I go ahead and replace BR2? What else should I check before I start taking the board apart?
