I have reset issues on Indy 500. I've read the pinwiki section on resets, it just isn't clear on a couple of points. I sometimes get a reboot right at start up, and other times I can play for a few minutes, and seems more likely when flipping both flippers.
Pinwiki mentions 9VAC coming from the transformer. At J101, I measured 7.8V - 8.0 V on pin1 and 7.3V - 7.8V on pin2 after a few tests and reseating connectors.
BR2 output is 8.64V and TP2 is 4.99V. Pinwiki says about 9V: is 8.64V close enough? Or is this lower because of the lower AC in I'm seeing?
Any thoughts on whether these readings indicate problem is before the board, or should I keep investigating?
