I have Shadow (WPC-S) that has been having some strange behanviour. Was working perfectly for months, and is now resetting on any double flipper press, and the coils associated with the fliptronics board are weak (magnet and flippers). I have quadruple checked all the standard flipper stuff, new mechs, new coils, no mechanical binding, but they are just weak - same with the magnet - it does not have power to throw the ball more than a few mm.
I can get rid of the reset by installing Rob Kahrs board, however the flippers and magnet remain weak constantly.
The thing that is strange (and since i have never seen this, leads me to believe it is the issue), is the 50V starts at 75V upon power up (normal), yet creeps up to around 100V. This would be over a period of around 2 minutes. I have checked with 3 different power driver boards as follows and compared it to an Indiana Jones:
All of the following had ONLY J101 and J102 plugged into power driver board
Power driver board 1 in Indy - Stable 75V
Then put Power Driver board 1 in shadow - crept up to 98V
Power driver board 2 in shadow - creeps up to 98V
Then put power driver board 2 in Indy 0 stable 75V
Just to check my sanity, grabbed power driver bard 3 (out of CFTBL that has been running fine for 12 months)
Power driver board 3 in shadow - creeps to 100V
Power driver board 3 in Indy - stable 75V
Power driver board back in creech - stable 75V
So, i also checked the AC voltages at J101, J102, and they are comparable - AC voltage on Shadow is 55.5V, it did fluctuate up or down 0.2V
So i am stumped as to why this would happen, there is 0.9 ohm between the earth pin of the power point plug and the headbox earth strap, so i assume everything is grounded fine. There is really only the thermistor, EMI filter, plugs and transformer that could be the issue.
I don't have any other machines that use that same transformer (has different plugs to most), so can't swap that - does anyone thing the thermistor or EMI filter is a likely culprit? I have reseated the plugs to and from the transformer 3 times, with no difference.
