Hi all.
After having some issues with resets on my JD I reflowed some solder joints on the power driver board for J101-3, fuse 113 and the LM323K regulator.
Now the resets have stopped but I am reading 5.75 volts at TP2. Out of interest, I tested the TP2 voltage on my DM. It is also high at 5.75.
The rest of my games are at 5 or below, as is normal.
Are these voltages too high? Will they cause any damage? If so, where should I look to rectify? The boards are clean with no hacks. The games play fine otherwise.
