New! Dark mode!
(Topic ID: 234406)
WPC Lamp Issue - Resolved
By gripwhip
1 year ago
  • 20 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by jfesler
    #1 1 year ago
    So, I thought I fixed a bad TIP 107 transistor which was causing double lighting on one of the columns. After replacement, everything worked great (about 4 games). Now, I am getting random lights with not much of a pattern. Column 1 (the one I replaced) is not working at all and getting multiple light on other lamps. Could it be the ULN2803? Other thoughts?
    #2 1 year ago
    Did you install regular LEDs (not the non-ghosting) in the game?
    If you go into single lamp test and see ones partially on when only one should be one, this would be one potential cause. You can install regular incandescent bulbs in place of the ones that are "ghosting" just to see if the issues go away.
    #3 1 year ago
    Thanks, but this is not the issue. It is not a ghosting issue. I even have the non-ghosting ROM. It was working fine, and then I am having multiple weird lightings across the matrix. Thanks.
    #4 1 year ago
    Did you test the transistor for solder shorts between the pins after replacing it?
    #5 1 year ago
    I will checked that, but as I said it was working great for 4 games or so. I will pull the board again tomorrow.
    #6 1 year ago
    Quoted from gripwhip:
    You should be able to test it while it is in the game. Instead of using the middle solder pin, use the top tab, which is the same. That should be a bit easier to ohm between the pins while it is in the machine.
    #7 1 year ago
    I did that. It is testing fine. This is why I am concerned it is beyond the TIP 107.
    #8 1 year ago
    J137 and J138 are tied together on the driver board. Swap the wiring to the other connector not being currently used. If the column now works, then you have a broken solder joint on the board connector.
    #9 1 year ago
    Good idea. I will give it a try tomorrow.
    #10 1 year ago
    I tried it. No luck. I did fix column one again. Needed to redo the solder on the TIP 107, but still no luck on the random lighting.
    #11 1 year ago
    Some progress at least.
    Do you have any mods that connect to any of the insert lamps? I've seen some connected to the wrong side of the diode and cause the same issue.
    #12 1 year ago
    Nope. I just have a ColorDMD installed.
    I am sending the board to Clive for repair. I think one of the chips higher up the chain failed. Besides, it could use the CAPs and BRs probably replaced. Thanks for your help.
    #13 1 year ago
    Following!
    #14 1 year ago
    Best to confirm the board is faulty in BSD or move the driver from BSD. You could have a playfield issue.
    #15 1 year ago
    These do not fail very often. I seen many more issues with the J101 and J114 connectors causing low 5volts, which cause boot issues and I see C4 capacitor leak often, just as Pinwiki mentions.
    #16 1 year ago
    Nothing wrong with sending the board out if it is faulty.
    Also, check into having NVRAM installed on your MPU board to get rid of the batteries. I love these things. I had installed over 200 already between all games I have worked on.
    #17 1 year ago
    Quoted from PinballManiac40:
    I used to be able to that, but I only have Stern games now other than BSD. I guess I will find out when I get it back. It was just too many weird lamp issues to make me think it was a diode that suddenly went bad or a playfield short. Frustrating. I now get to wait....
    #18 1 year ago
    For some reason I was thinking this was on WCS. I'm in too many repair threads it seems.
    A diode could be smashed up against the metal part of the #44 lamp socket or against a metal kicker bracket. Wouldn't hurt to look at all the #44 lamp sockets under the playfield for potentials.
    4 weeks later
    #19 1 year ago
    Update: I finally got the board back. It was not the board. It needed some connectors repaired and general bulletproofing, so I guess it was not all that bad other than the waiting.
    I thought I must depressingly have a short somewhere so I started to try and figure out a pattern of the double/triple lighting. The single lamp test kept pointing to one socket that seemed to be lighting the majority of the time when it should have been off. I thought it might be the socket diode at first, so I replaced it. It buzzed on the diode test, but I think it was because I did not disconnect one leg. It seems like sometimes you need to do that and other times you don't need to do that.
    Then I tried just removing the LED. The problem went away. I thought that was strange. I played with the socket some, checked the wiring, and put the LED back. It was the same issue. Next I tried a regular incandescent bulb. The problem went away again. I thought is this some weird ghosting LED issue??? I then tried a new LED. The problem went away and has not come back.
    So, the actual problem was a bad LED. I guess the light emitting diode shorted on??? I guess that makes sense since it is a diode, but I really thought it was the board and then a playfield short.
    I hope this help someone else and thanks for all the previous help.
    #20 1 year ago
    Thanks for the follow up.
    $ 7.00
    $ 66.99
    Lee's Parts
    $ 48.00
    $ 29.90
    The MOD Couple
    $ 29.25
    The MOD Couple
    COINTAKER.COM
    CzTV Mods
    $ 5,999.00
    Classic Game Rooms
    £ 50.00
    Cabinet Parts
    PinballToys
    $ 85.95
    $ 24.99
    Bent Mods
    $ 999.00
    Filament Printing
    $ 19.95
    $ 4.49
    $ 42.00
    $ 54.99
    Pinball Photos LLC
    $ 125.00
    $ 110.00
    AMCO
    Medisinyl Mods
