Hey all. I’m having a small but agonizing issue with my fish tales. Although this has been mentioned before, none of the solutions seem to work for me.
The playfield hinge does not “click” into the mounting holes unless a large amount of force is used with a specific angle. It seems as if the little metal tabs that rotate on the hinge get stuck in between the two sets of mounting holes. The Getaway that I have also worked on had not had this issue, and I have been able to pull the playfield out an up very easily.
If I lift the playfield up a foot and then try to pull it forward, there is no click either.
