Quoted from Crash:I know for a fact that the only role EOS switches play in Williams WPC games is telling the CPU to switch the voltage during a flip. However, common knowledge here suggests otherwise. When someone has a weak flipper one of the first responses that comes up is to check/file the EOS switches. Flipper coils get their power from the Fliptronics board which is independent of the condition of the EOS switches. Am I wrong, or is there just some confusion on the issue?
Until and unless you put the output of the fliptronics board through a capture scope, all you have is conjecture.
The proper way to test any and all theories is to tape up an EOS switch on a fliptronics machine, then read the pulse width, as that'll be the maximum allowed on time. Then take off the tape, and adjust the EOS switch so that it closes early. Read the on time again. If it's the same, then the EOS isn't used in the timing on the initial flip.
I don't foresee myself getting bored enough to try this experiment for quite a while. Until somebody does it, all you have is conjecture.
I *do* know that data east flipper boards do not use the EOS for their initial flip. My gut feeling is that this is what contributes greatly to the different feel between DE fliptronics and WMS fliptronics. But that's just conjecture at this point.
