I have a problem with the driver board in my getaway. This problem is absolutely in the driver board cause when I replace the driver board the problem goes away.
Opto 1 which is the first opto for the supercharger doesn't work at all and is "stuck open". If you go into test mode and activate any of the pops or slings you will get a momentary closure of opto 1. If you disconnect j102 which is the AC in for coil and flash lamp power the opto come back to life and works correctly. Then if you activate pops and slings it doesn't cause a momentary closure of that opto (but the coil power is deactivated too). Also, while in test mode if you have coil power plugged in and disconnect the ribbon cable between the driver and CPU board the opto 1 works correctly and the pops and slings do not activate opto 1 either. I need some help in trying to figure this out. I'm guessing it's one of the chips in the driver board but don't know which one to start with.
Here's the video.
