Starting to pull my hair out with this one so I'm hoping someone can help me narrow down where I went wrong. My JD DMD has been taking a while to warm up and the high voltage was low. I'd been putting it off for a while and figured quarantine was finally the time I would rebuild the HV section of the DMD controller board.
I'm now getting 116v, 104v and the 60v reads about 4v and then starts dropping towards 0 with the DMD totally dead. I swapped in the board from my BSD and it boots great, so I know the problem is on the board somewhere.
I'm pretty disappointed that I somehow got a worse result after rebuilding it and figured I must have either shorted something or I'm missing connection on a trace where I should have one. I spent the last 3 hours going back over every component making sure they all tested good and following all the traces I could see to make sure continuity was good and nothing is jumping out at me.
I can get some pictures of the area tomorrow if it would help. This seems like a common issue with these boards but none of the fixes in the threads I found seemed to get me anywhere. I didn't replace any of the caps so that is one of the last things left I can think of but any starting points would be helpful.
