The Shadow's giving me some trouble... Power on and everything works as expected. Part way through the first game (at different times during play) the DMD will go blank, then displays a few glitchy images and eventually stays blank. At this point power cycling doesn't reset the display, the game needs to be off for an hour or so, then comes up fine, but goes blank again as described above. Also doesn't require gameplay, if left on, within 30 minutes of attract mode the DMD will go blank. Prior to blanking the Display Test works fine and the RAM passes. All voltages at the power connector are normal before and after going blank. I have also reseated all ribbon cables with no change. Any thoughts? Thanks in advance.
