(Topic ID: 197088)
WPC CPU pinled problem, Terminator 2
By fly
1 year ago
  • 62 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by fly
There have been 9 images uploaded to this topic. (View topic image gallery).
There are 62 posts in this topic. You are on page 1 of 2.
#1 1 year ago
Hi,
I installed a WPC CPU from PINLED and the game does not start.
D19 - lights up
D20 - flashes once
D21 - lights up,
I have a new ROM mounted and still have the same problem: /
#2 1 year ago
Unplug all the ribbon cables. Does this allow the leds to boot?
#3 1 year ago
Quoted from fly:
Hi,
D19 - lights up
D20 - flashes once
D21 - lights up,
What are the dipswitches set to? Post a picture of them please.
#4 1 year ago
#5 1 year ago
My question was ignored. I'm draining this thread
#6 1 year ago
Sorry I'm no help here with this one as I don't know anything about that CPU.
#7 1 year ago
Can you confirm you have rhe same problem after doing this?
Quoted from markmon:
I recall having a boot up issue when I bought one a few years ago. I seem to recall the dipswitches had to be configured a certain way. I will try and find a picture.
#8 1 year ago
sorry i did not reply, after removing the plug it is the same. I also think it's a matter of setting dipswitches
#9 1 year ago
6 or 7 is wrong since one of them should be off according to the chart.
#10 1 year ago
Those were the original dip switch settings when you received the board?
Try these settings
W1 on W2 off W3 off W4 on W5 off W6 off W7 on W8 on
#11 1 year ago
I bought the card from another forum user, he used it in Indiana Jones.
I'm out of the house now, I'll check the settings and let you know.
Thank you.
#12 1 year ago
Quoted from PinballManiac40:
Try these settings
It works!!!!
Thank you very much
#13 1 year ago
Quoted from fly:
It works!!!!
Thank you very much
You are welcome. I never did find that picture from several years ago.
Is it holding the last scores and free play after turning the game off and back on?
You can upgrade the board to NVRAM and remove the battery if you want, but it would need to change some dipswitch settings. The current battery should last over 5 years.
Quoted from fly:
I find it hard to believe it worked for him with those dipswitch settings.
#14 1 year ago
No,
#15 1 year ago
Try dipswitch W6 on W7 off w8 on.
#16 1 year ago
Quoted from sprite:
I do believe this to be true.
#17 1 year ago
same thing, no change
#18 1 year ago
Ok. I got a picture from my friend who bought the game with the PinLED MPU in it.
Try this again. These are the setting on the board.
#19 1 year ago
With the power off, measure the voltage that is across the battery (the cylinder just above the switch).
#20 1 year ago
Sorry, no change
#21 1 year ago
Can you measure this battery voltage?
Quoted from Schwaggs:
#22 1 year ago
no volts, that is battery to exchange
#23 1 year ago
Quoted from fly:
Since the battery has no voltage, do you want to locate a new lithium battery or install a NVRAM? It is possible that the battery discharged faster due to a shorted diode on the MPU board.
http://www.pinitech.com/products/6264_nvram.php
#24 1 year ago
Today I will install a new battery, I will see how it will be
#25 1 year ago
Make sure it is a Lithium. Any others will leak.
#26 1 year ago
#27 1 year ago
Hoping for some good news with the new battery.
#28 1 year ago
Battery not yet mounted because I have another problem.
On test switch "always closed" appears and disappears as it is not active it does not work "gun shoter" as it is active it gun works.
does any diode have a short circuit?
#29 1 year ago
Check to be sure the bottom right 2 connectors of the MPU board are not shifted over by one pin. Should be connectors J206/J207 and J208/209 depending on which connector the wires are plugged into.
If they are connected correctly, test out all the switches in the game to see if you can narrow it down to a row or column of switches.
#30 1 year ago
All other switches work properly.
#31 1 year ago
Quoted from fly:
Not sure I understand the problem with the gun shooter.
If you are saying the Gun Shooter only works when the Always Closed is active, then yes, a shorted diode is possible. Also possible that the switch is wired wrong. Can you post a picture of the Gun Shooter switch snd a working switch in the same row/column as the Gun Shooter and Always Closed.
The placement of the white and green wires on the switch need to match the same wire placement of a working switch.
#32 1 year ago
#33 1 year ago
What is wrong with your original T2 MPU? Since it seems you have 2 Indy Jones machines, can you swap a MPU into the T2 (swapping game ROMs) to see if it is an issue on the MPU board?
#34 1 year ago
Also keep in mind, the 'Always Closed' switch is not an actual 'switch', just a diode on the coin door interface board. It's just a simple diode.
Depending on the game's base OS (i.e. The version of the base OS), the game won't even boot up properly withtout seeing 'Always Closed' closed.
#35 1 year ago
Today I mount a plate from GETAWAY and see,
If there is the same problem, I will check the plate, coin door.
Which diode is responsible for "ALWAYS CLOSED" ???
#36 1 year ago
What is a plate?
#37 1 year ago
Usually a round (but can be other shapes) flatish piece of crockery that is primarily used to hold food and made mostly from porcelain or China.
Would you like to know what a knife and fork are????
#38 1 year ago
ups, sorry BOARD
#39 1 year ago
Quoted from fly:
Should be D2 on the coin door interface board. That's what the schematics say, I don't have a board on-hand to check against though.
#40 1 year ago
After mounting the mpu with Getaway, still the same, I'll check now, Coin Door Board
#41 1 year ago
I replaced the diode D2, and still the same
#42 1 year ago
Probably a good time to change the battery on the PinLED MPU board since the problem is still some where in the machine.
#43 1 year ago
By chance, do you hear more than one switch activating when you pull the gun shooter switch? If so, this can signify a broken wire in the row/column.
#44 1 year ago
No, how it works is just one sound.
switch always closed is inactive, gun does not work.
Today I'm going to put a coin door board with Getaway and see.
#45 1 year ago
Quoted from fly:
That sounds like a good idea, but I do not think both boards are compatible between these 2 games.
#46 1 year ago
Fly, on your post #32, your picture is not showing any normally closed switches on your DMD during switch test. Is that still the case with the Getaway MPU?
Can you measure the 5v on TP2, 12VA on TP3 and 12unreg on TP1 of the driver board?
Here you can see all the normally closed switches on my T2.
Can you check the wiring for any corrosion on all these switch inputs at the bottom of the MPU? J212 goes to the start button and the gun shooter switch and I am suspecting you have some green or white battery corrosion on some of the pins.
#47 1 year ago
yes,
yes, some are green
#48 1 year ago
Which was a reason I was worried why the MPU board was replaced. You need to check the other wired connectors as well at the bottom of the MPU as well. All corroded pins/connectors need to be replaced and likely need to trim off an inch of wire as well since the corrosion will run up the wire.
#49 1 year ago
ok, I'll check it out.
#50 1 year ago
The corrosion is causing high resistance and the reason for your closed switches are not showing up in the switch test.
Did you replace the battery on the PinLED board? I was interested in knowing if the battery voltage is good now.
$ 9.99
$ 159.99
Flashinstinct
2,600 (Firm)
Pitts, PA
KAHR.US Circuits
$ 99.99
Trade
Machine - For Trade
La, CA
€ 12.50
Playfield - Plastics
Multigame
3,000
Oceanside, CA
€ 3.70
Gweem's Mods
$ 16.50
€ 222.00
Buthamburg
$ 19.99
$ 259.00
Tilttopper
$ 14.95
PinSound
Watertown, WI
$ 40.00
Yorktown Parts and Equip
