I have a STTNG that died the other night. The initial symptom was D20 wouldn't flash. I played around with the connectors and discovered that if I disconnected J601 from the display board, then D20 would flash. So I ordered a Rottendog replacement display board. But when I installed it, the symptom was the same. And when I disconnected J601, I discovered that the D20 flashes (and the game starts), but it eventually stops flashing, usually within a minute after powering on.
Any ideas what might be going on or where to look? I assume it must be a CPU board issue. Just for fun I tried a Kahr board to make sure I had a clean 5V & it didn't change the symptoms at all.
