(Topic ID: 184009)
Wpc coins door replacement
By dropdeadhippie
7 years ago
    #1 7 years ago
    Bought a replacement coin door for my getaway. Old door had interlock switch holder built into upper left of door frame. New door has no switch holder, just a switch actuator bracket on bottom left. Anyone know best way/parts to adapt the new door? I don't want to just bypass the switch
    #2 7 years ago
    I had this same problem during my Fish Tales restore. I ended up getting a bracket from Marco:
    http://www.marcospecialties.com/pinball-parts/01-11271
    And then an actuator from Marco which I modified a little bit and added to the door:
    http://www.marcospecialties.com/pinball-parts/27-4921
    Can't say its the most absolute perfect solution because the actuator rubs the door a little bit but if you mess with it you should be able to get it to work and look great. I attached a picture so you can see how I set mine up.
    #3 7 years ago
    Awesome. Thanks for the info and pic!
    This page was printed from https://pinside.com/pinball/forum/topic/wpc-coins-door-replacement and we tried optimising it for printing. Some page elements may have been deliberately hidden.
