I've got a Fish Tales with the standard WPC Audio Board (A-12738) that have worked fine until a few days ago when the sound (both music and callouts) have started to behave strangely while playing. The issue is that the sound comes and goes randomly; sometimes it slowly fades out (over a few seconds of time) and I can only hear the sound faintly and then it will fade back in again later. Other times it just vanishes completely and a random time later comes back again with normal volume. Loosing a ball and progressing to the next one doesn't remedy the problem if the sound is weird at that moment.
The problem can appear within a few seconds after turning on the pinball machine (not played at all for a whole day) and then starting a one player session, so probably not directly heat related.
I don't have an instrument to measure the temperature of the large heatsink but holding a finger on it is no problem; the heatsink is warm but won't get hot.
When I put the game in test mode for sound and kept it playing it worked flawlessly for several minutes without any issues. I then let the sound test continue playing while wiggling/pressing on all PCB connectors on the sound card that have cables connected and sound works just fine without any problems.
As a side note, the original CPU card had a problem after leaking batteries when I bought it about a year ago so I replaced it with a brand new card, so my current issues shouldn't be related to the CPU card at all.
I have not replaced the ribbon cable going to the audio card but wiggling it around in music test mode doesn't introduce any audio problem, coupled with the fact that the DMD behaves 100% all the time and is located on the same cable make me think it's ok.
The issue seem to be present only when playing (so far at least), could that indicate it's a problem with failing voltage input to the card when other things are in play like coils, flashers and other PCBs drawing power?
I've never had sound problems on any of my games before so consider me a newbie on this front. I can't find any dedicated test points on the card (like on the power driver board) so I guess I have to measure directly at the incoming connectors. Should I measure for 18 V AC between J501-1 and J501-4/6 and for 5 V DC on J502-1 to any ground?
I'm aware that many replace the old capacitors on this card. My understanding is that is done when sound gets distorted/sound bad but is not related to "volume" problems similar as mine, or am I wrong? Should I just shotgun it and replace all the normally recommended capacitors and see if it helps? Visually all components on the card looks good, nothing burned, no leaking or bulging capacitors.
Any help appreciated.
