So my Tales of the Arabian Nights has been sitting unplayed for a few months, and since I've started turning it on again, it's been displaying some weird boot behavior. Here's what I've seen, in the order I've seen it:
1. First time powering up: got factory settings - tested the batteries, and they were dead. Like dead-dead, completely drained. That seemed weird, since I thought they were not very old. Checked for corrosion, swapped the batteries. Everything seemed fine for a few power cycles.
2. Then I noticed I was getting a single "bong" at the end of the attract loop, and also right before the high scores. Might have sounded the same as the power-up bong, but my memory is hazy. There didn't seem to be any simultaneous resetting or anything - attract loop continued as normal. There were just these two stray bongs at those two points.
3. A couple power cycles later, I got weird display crap on start. Difficult to describe - it was the normal animation, but some flickery & messed up parts. Also, briefly got that "failing display" thing, where you lose some rows in one quadrant of the DMD.
4. This morning I got: "Testing..." then RESET; then "Testing...", attract mode briefly, then RESET; then "Testing..." and normal attract mode. (All in one power-up.)
5. The last few power cycles have been fine. No glitches, resets, or stray bongs.
This is one of the weirdest & most inconsistent set of symptoms I think I've seen. I'm not even really sure where to start - though my gut says next step is to swap in the AV board from my Medieval Madness and see if that works.
One bit of relevant context: I rebuilt the high power section of the AV board a year or two ago, after the DMD lost power. (The thread: https://pinside.com/pinball/forum/topic/totan-dmd-dead-gi-acting-funny) It seemed to do the trick, and I didn't notice any further weirdness until just now. The one exception being the strange way that only the upper-right quadrant of the GI lights up at boot time, until it enters the self test. All my other games give either no GI or all GI prior to the self test.
