My MM came up with a credit dot for Right Troll Up Switch Bad. I checked and it was coming on briefly when the troll popped up but would not stay on so I adjusted it so it would. It works in test mode as well as the switch for the face of the troll when it gets hit. I do get switch 75 R Troll when testing manually but the error still shows up after cycling power.
My experience with WPC switch errors is that one you test the switch (like a rollover has not been tripped in a while) the switch error clears. The troll assembly is a little sticky, the left one is smoother but it works fine during gameplay.
Bob
