I have an AFM that suddenly got stuck on spanish instead of english.
The mpu jumpers are set correctly.
Spanish is selected as the active language in the menu settings, even though the factory default tag shows for english.
If I try to change the language setting to anything other than spanish (english, german, french...it doesn't matter), it always reverts back to spanish.
Other menu settings seem to save normally.
I've done a factory reset, erased and re-burned the game eprom, checked continuity for the dip switches (although since english is make as the factory default, that seems to tell me the dip switches are working). This game uses ram with a coin cell battery, and I left the battery out for 10 minutes and put a fresh one in (3.2v) since the original was a little low (2.9v).
Any ideas?
