(Topic ID: 255113)
WPC 95/NGG blowing fuses 103/104 after PS repair
By tamoore
14 days ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 14 days ago by LTG
#1 14 days ago
My NGG has had a reset problem for quite some time.
I've replaced the rectifier diodes previously, which didn't fix it.
I just replaced the capacitors at C8,9,10,11 and 12.
Good news: I can activate both flippers without the game resetting.
But...
Now when I turn the game on, 50v fuses 103 and 104 blow. 102 is fine (coils 9-16).
Nothing blows with the J133 connector unplugged.
Any ideas on where to start looking? It doesn't seem like the capacitors I just replaced would have an impact on the 50v.
Thanks.
#2 14 days ago
Quoted from tamoore:
But...
Thanks.[quoted image]
I'd suspect a short on some of the coils first, check the area around each one and make sure nothing's touching
#3 14 days ago
Quoted from dudah:
That's a good thought and something I considered, but other than the random reset, everything was working perfectly before I changed out the capacitors. Never took the glass off. It would be quite a random coincidence for two different 50v strings to be shorted out at once.
#4 14 days ago
Ohm out those wires on j33 you should find the issue.
#5 14 days ago
Verify that you didn't reverse the polarity on any of the replaced components.
#6 14 days ago
Quoted from ForceFlow:
They're all pointy the same (correct) way. Thanks for the idea!
#7 14 days ago
Just as an FYI, sometimes older capacitors mark the positive terminal, rather than the negative terminal. However, I'm pretty sure on WPC/WPC95, they're new enough that all of them mark the negative terminal.
#8 14 days ago
If you replaced any resistors, measure them with a multimeter to verify their value. It's possible that they might be off, or the wrong one ended up in a batch by mistake or through sorting/handling.
#9 14 days ago
And they all might not face the same direction on a board.
4,300 (OBO)
Sale Pending!
Evart, MI
$ 50.00
Gweem's Mods
