Can someone tell me where to order the correct socket for the PLCC chip? Mine had a little acid damage and the board became intermittent. Some of the contacts are damaged and I want to replace it. I found this number 70206224 at Allied Electronics with the mfg # 940-44-084-24-000000 but i am not sure if it is the right part or not. I hate to spend 4X's as much as it cost on shipping just to find out it is wrong. Thanks for the help. pdf here http://www.alliedelec.com/images/products/datasheets/bm/MILL-MAX/70206218.pdf
