(Topic ID: 310445)
WPC-89 start button will not start game
By martymart
2 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by martymart
    #1 2 years ago
    I am currently working on a Williams White Water and the start button will not start a game.
    The game boots and the "start switch" works in test mode and the game is in free play. All balls are also installed with trough switches activated.
    Any thoughts on what be causing this issue.
    #2 2 years ago
    Credits on game or set to free play ?
    Battery damage on CPU ?
    #3 2 years ago
    Quoted from LTG:
    It is set to free play although it has the same issue with credits.
    I should have also mentioned that it has a very clean homepin aftermarket board installed (has coin battery with no corrosion).
    #4 2 years ago
    Are any other switches closed in test that shouldn't be? Shooter lane switch working properly? Not stuck closed? Factory reset or pulling the battery for a few minutes is worth a try.
    #5 2 years ago
    Does it give any error messages on the screen when you press it? Is it lit? (It should be on free play)
    #6 2 years ago
    Quoted from bcd:
    There are no error messages. The machine is currently on free play although the start button doesn’t trigger a game start. The start button works in test mode.
    #7 2 years ago
    Quoted from phishrace:
    Not that I recall. I will have to check it again.
    This page was printed from https://pinside.com/pinball/forum/topic/wpc-89-start-button-will-not-start-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
