I recently purchased a non-working Black Rose that when turned on would display the typical factory reset display, but the coindoor control buttons were nonfunctional and could not get beyond that point. The batteries on the CPU had leaked with damage to components below it. Parts were literally falling off the board. I purchased a replacement CPU from Pinball Basement and transferred the U4, U6 and U9 chips as required. These chips did not appear to be damaged by the alkaline leak, or anywhere close to the leak. With the new board installed, I still had the same problem where the coindoor buttons would not work.
I checked and there is no short at the buttons due to bending or a loose screw, etc.
I tried shorting the switches at the coindoor with no response.
I disconnected J205 and tried shorting the pins for those switches with no luck.
The last couple times I turned the game on the screen now says check Fuses 114 and 115 (power driver board). The fuses test fine with a DMM, out of the game. The coindoor buttons still don't work.
BR1 on the power driver board tests ok.
I disconnected and reconnected the molex at the transformer.
No change.
Any help and suggestions would be appreciated.
