- Hello, I replaced BR1 and BR 2. All TPs test out good and now Led 1 and Led 6 are lit but I still get the check F114 and F115 message but at least now I'm able to get into the menu.
-I also now get a broken gun message and all the balls load up in the shooter lane, all four. I did a switch test and I'm getting T3-11 thru 17 "GRND Short."
- D1 and D2 Diodes test out good and all fuses test out good. I also tested D2 to C1 and it tested for continuity.
- What should I try next?
Thank you for all you've done top help me with this problem. Hey, I learned how to replace bridge rectifiers, first time.
Robert
