Hello all
Well I have a few issues that started showing up.
1. Sometimes I boot up the game and there is no audio. Upon a reboot everything works
2. Yesterday I had some lights go out and when I lifted the pf they went back on. I checked everywhere for a loose connector and could not find one (picture attached in hopes that someone knows what connector I should be looking at
3. The damn left VUK is driving me nuts. Sometimes it will rocket a ball over the wire form. I test it, reposition, bend it and test and everything works. I even adjusted the coil strength down. Then for no reason the coil will just launch the ball across the PF. Seems to be a software glitch at this point. Also seems to happen in cystal ball mode and if the initial attempt to up kick falls back in the hole.
My guess is its software related, though I would like to adjust the wire form so it does not fly off the PF. I have had zero luck adjusting the wire form for any coil strength above 17
Any help would be appreciated
Post edited by The_Dude_Abides : Please do not use all caps in your thread headers in the future.
