(Topic ID: 170798)
Iron Maiden SarcophaGus mod
By gouveia
6 years ago
  • 6,251 posts
  • 620 Pinsiders participating
  • Latest reply 14 days ago by rockrand
  • Topic is favorited by 271 Pinsiders
6 key posts have been marked in this topic (Show topic index)
There are 6,251 posts in this topic. You are on page 120 of 126.
#5951 11 months ago
Quoted from darkryder:
Received mine today as well, looks incredible! Are you guys trimming plastics or finding that's not necessary? I have a Maiden LE.
Thank you so much! I'm really glad you like it.
Regarding the plastic, the only other option I can see to not sanding down the edge is to somehow move the plastic slightly to the left and re-drill holes back there for the screws. It just hangs over the opto a bit too much, and I didn't want to make him smaller just for that. I actually don't use it anymore in my game and don't miss it.
#5952 11 months ago
Really really nice work Steve. I am so impressed by the quality of this guy. Well done sir!
#5953 11 months ago
Thank you Vitty! Nice photo.
#5954 11 months ago
Gus is going back under.
#5955 11 months ago
IBTL....in before the list????
#5956 11 months ago
You're already in!
#5957 11 months ago
I have found that I definitely need the left ramp plastic installed. The ball gets some air going up that ramp and doesn't like to go into the sarcophagus lock without it. I just don't have a belt sander. Was going to try and sand it down by hand, unless you guys have a better idea?
#5958 11 months ago
Can you "score" it with an exacto blade? If you carefully cut back and forth enough times using a straight edge, it'll fall right off. You can then sand it down with fine grit sandpaper to make it smooth again. It'll work the same, just take a little longer. If you'd like, I can make a video showing you how.
#5959 11 months ago
Quoted from PinCrush:
I posted day 1 that I missed the initial list, but I don't know if that means I'm on the "backup list". If not, can I please request to get on this list?
Looks amazing.
Thank you.
Hey PinCrush,
Sorry I missed your post. I've got you on my list for this next round.
#5960 11 months ago
Quoted from gouveia:
Good to know that works. I'll give that a try. Thanks!
#5961 11 months ago
Hey PinCrush,
Thank you, sir. Exciting.
#5962 11 months ago
Quoted from NightTrain:
Of course! Just take your time, and put a bunch of pieces of tape over the Icarus graphic to make a straight line. That way if your blade wanders, you won't screw the good side up.
But take your time and use a straight edge and a good sharp blade. And try practicing on a spare piece of plastic first.
Oh and did I say take your time?
#5963 11 months ago
I forgot about this. Duh...I've got one. It works great! Just use it like an exacto blade. You can find it at Lowe's or Home Depot for about 6 bucks.
#5964 11 months ago
Same here, fast shots ride high and doink off the diverter. I don't want to modify the old plastic so am making a new one from a sheet of lexan from home depot.
#5965 11 months ago
To help out If any of you guys need a replacement plastic instead of belt sanding the original let me know.
I can source a clear laser cut replacement for $14 it works out with the exchange rate at the moment.
Postage to the usa is $13 tracked or $7 untracked
#5966 11 months ago
Or as Sutol. Maybe he can get you one like the piece his friend made in post #5861.
#5967 11 months ago
You beat me to it! Great!!
#5968 11 months ago
I got the replacement plastic in place....... Just need a Gus to sit next to it next week
#5969 11 months ago
Gus #6 ready for action! Plus my half-assed ramp cover, only thing in the parts bin that sorta fit
#5970 11 months ago
Very cool! It looks great! Now you’ve got a few options.
#5971 11 months ago
Quoted from Sutol:
PM sent
#5972 11 months ago
#5973 11 months ago
I repurposed the yellow flasher that needs to be removed under the playfield. and used it for the Gus flasher on the top side of the playfield.
This is similar to what Steve suggested in his YouTube Gus install guide. But, instead of using a 1 or 2 SMD warm white bulb. I thought a 8 SMD yellow flasher would give Gus a very nice bright yellow glow….
29483776-5E05-43C4-A27B-B426BEF7BE76 (resized).jpeg91984578-3C4A-4027-94FD-AA91167A294F (resized).jpegD0E91143-AD76-4174-B8A7-185F992335E9 (resized).jpeg
#5974 11 months ago
That looks great! I actually used that bulb for awhile as well. It really brings out the gold.
My main problem with the white flasher is it's just too bright once you put Gus in there. It's obviously supposed to be a "Shoot at this thing" light because the original piece doesn't look like a sarcophagus at all. I remember my brother-in-law was playing it for the first time awhile ago, and when it said "Shoot the sarcophagus to open Pharoah's tomb" he was like "Where's that?! Where's that?". So I had to point to it and say it's that little boxey thing up there.
With Gus in there, it's pretty obvious where the sarcophagus is. I just think he looks better with a dimmer light, and the warm G.I. bulbs make the game look closer to Maiden's stage lighting.
#5975 11 months ago
Just finished installing Gus and then played the crap out of Maiden LE. I haven't played in over a year and after a few warm up games, I went on a tear and put up a new GC of 613M. The sarcophagus mod is just awesome, his red LED eyes really add to the effect! Going to order the staircase decals for the ramps and a few other goodies for this legendary game as it's been covered in dust for a while. I'm noticing significant flipper fade on long games, so also going to order the PinMonk cooling kit. My manual and auto plungers don't work for jack either, if someone has the stronger replacement coil part to fix that, please post it here. Thx
29CFFFE3-7536-4308-B94F-2808FF5DDAFD (resized).jpeg36429332-17B6-4460-BC0C-0F539AF6D444 (resized).jpeg3E51ADAA-B2C4-40F4-B556-DC251A1A0CD4 (resized).jpeg6D167485-FF23-4D6B-AEB1-C8562FDD54A0 (resized).jpeg760EEF16-CA89-4975-9906-C47B8EBA2275 (resized).jpeg79F4924B-C0B7-4D4A-A389-23DED0B1A510 (resized).jpeg7B63AF6C-E0F7-47E5-B19C-5064A144BB68 (resized).jpeg
#5976 11 months ago
Awesome!! He looks great.
Yeah, that's what I meant earlier about him making you play better. There's just something more fun about hitting a physical toy with a "personality" as opposed to a boring captive ball. Plus hitting him over and over does a lot of good things for your score. And even if you miss him, you're still going to hit the spinners and loops and all that.
Really glad you like it! Thanks for the pics.
#5977 11 months ago
I agree, funny how I put up a new GC score right after installing Gus! It's definitely a lot more fun hitting the mummy shot now. Maiden is an absolutely incredible pinball machine, I never get sick of it. The insults from the beast are so damn funny. "Die will your balls gone" always puts a smile on my face, lol.
I have PinMonk anubis mod for my game I never installed as I'm not skilled with art/craft painting. If you feel like painting an anubis 3D mod, I can send it to you and pay you for your time. Been wanting to install it for a while now. I also have a set of bony flipper bats for Elvira HoH that are plain white and need to be colorwashed and painted.
#5978 11 months ago
Here is my Gus with a blue led strip triggered to the shaker, blue strips under the mech shining up that flashes with the eyes, and red spots.
#5979 11 months ago
I love it! I debated putting more light under there, but then figured with the matrix connector you guys could do that if you wanted. Blue looks pretty cool.
#5980 11 months ago
This mod makes my right ramp Egyptian archway mod look like total shit.... I've got to do something now. Would be awesome if it matched Gus' aesthetic.
#5981 11 months ago
Hahaha. Sorry about that. Glad you like it!
#5982 11 months ago
Hi, Are these still been sold or has it run to the hills yet?
#5983 11 months ago
The first forty have run to the hills. I’m in the process of making more though, so if you’d like I can add you to the list. Just PM me.
#5984 11 months ago
Gus #2 reporting for action in Canada.
25F1DEF0-7F1B-444E-886D-60B214E108C0 (resized).jpeg7FBAB645-1D3C-49AB-8935-E6B791D97A3C (resized).jpegF2D7AD7B-C702-4AC5-9038-F10CEFBADE74 (resized).jpeg
#5985 11 months ago
Quoted from Apollyon:
This is beautiful and I need this
#5986 11 months ago
I'd like to add a note about my experience with Steve.
Excellent communication throughout. Only once it was ready to go, did he asked for payment. Then, when I paid, I got a shipping tracking number a couple of hours later. Came expertly packaged with a thorough install video.
The quality of this mod is outstanding. It is a real work of art. Solidly built. Expertly painted. It just looks amazing.
But once you get it installed, its like the game comes to life. Mummy multiball is a new experience with Gus. The way he moves, the way the eyes glow and flash, the way the flasher flashes on Gus when you need to collect a Mummy MB jackpot. This is EXACTLY the way the game should have shipped. Its like the ball actually goes into a sarcophagus, not a bland piece of plastic.
If you are hesitating about ordering one, don't. You will regret not getting one later. Sure its a bit pricy, but you get what you pay for. QUALITY!!!
#5987 11 months ago
No.37 made it to the Uk this morning.
Amazing work steve.The thing that struck me the most is the height of it.
One thing I would echo to what Steve says in his install instructions is going to warm white for the Gi.
I did this a good year ago along with Twd and it makes both games really come alive.
Well worth the effort.
#5988 11 months ago
Still trying to get added to the next list. Thx.
#5989 11 months ago
I really want to be added to the next batch list
PM is also sent.
#5990 11 months ago
Wow! Thanks for taking the time to post such a nice review.
And that is EXACTLY what I want you to experience when he’s in your machine.
Steve
#5991 11 months ago
Quoted from Sutol:
Well worth the effort. [quoted image]
Gus made it over the pond! Thank you!
And yes. Warm white GI. You won’t regret it. In fact, I put a small piece of masking tape over the lights inside the pop bumpers and a strip over the leds behind the backglass as well. You can’t switch those out, and the tape works really well at warming up those lights just enough to match the rest of the playfield.
#5992 11 months ago
I’ll gladly be in the next batch please!
#5993 11 months ago
Amazing!
Installation instructions were straight forward and easy to understand.
A beautiful center piece for IMDN.
Another awesome mod from the great G.
#5994 11 months ago
GUS received and it is Glorious.
Everything from packaging to the Mod Of the Year, all first class.
When I first heard about Steve it was here with the Maiden Sarc Mod (GUS). Hadnt seen his WOZ mods or anything.
Then I saw the messages pictured below,
And didn’t quite understand what was being discussed.
Now, I know.
This Gouveia Mod is Next Level.
Brilliant.
Thank you.
#5995 11 months ago
PM sent. Just found out about this mod. This is really going to make this pin Pop (like it needs help)
#5996 10 months ago
Hey everyone!
I've got quite a few more Guses (Gus's? Gus'? Sarcophagi? Sarcophaguys?) to make, so I decided to get all of the dirty work done first. I finally have enough parts cast and sanded and drilled to get things started up again. And I won't be painting all of them at once this time around, so I can focus on smaller groups and get them out to you quicker. I've also got a bunch of PM's I haven't gotten around to yet so I apologize for that. I'll definitely get back to you today.
Thanks again for all your nice comments and May the 4th be with you!
Steve
#5997 10 months ago
...for the win!
#5998 10 months ago
Hey everyone!
Steve
I sent you a PM.
Thank You
#5999 10 months ago
I've had a couple people now order my new hammer mod without actually owning a Metallica. Which I really appreciate, don't get me wrong, but it's slightly crazy behavior.
And ... I'm starting to understand it now, because I don't own an Iron Maiden and I have this irrational urge to have this mod. It looks spectacular, really top notch work.
With everyone and their uncle—and their uncle's "teams"—pumping out mods these days it's hard to stand out. But the quality work that fills a true need really rises to the top, and this is clearly that.
#6000 10 months ago
Hey Aurich!
Thanks for such a nice post man! I don't know if you remember, but I met you briefly up at Chris' house years ago at a tournament. You were really helpful with some questions I had when I made my first witch. I remember calling you the hammer guy once I realized who you were, even though you've obviously done other things I learned about later. Very cool to see you making them again. They look awesome.
For the rest of you, I only have a few slots open until I close the list again. I cast another forty pieces so that's all I have. It actually took me a little time to get back into the groove, but I'm happy to say that #41 sure looks a lot like numbers 1-40. So at least I know I can still do it.
For those of you new to the thread, the mod is $550. I do the whole thing by hand, so it will take some time to get it to you. And I don't ask for payment until I actually have something to sell you, so no money up front. I'll send you a PM when it's ready and you can pay me then. If I don't hear from you for a couple of weeks or so, I move on to the next person on the list. Pretty simple.
So thanks for your patience everyone. More sarcophaguys coming soon!
Steve
$ 65.00
Tools
Performance Pinball
Tools
YouBentMyWookie
Other
This page was printed from https://pinside.com/pinball/forum/topic/woz-witch-red-smoke-mod/page/120 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
