(Topic ID: 118631)
WOZ Winkie Guard Problem
By RJL
9 years ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 9 years ago by RJL
#1 9 years ago
Hi,
When I boot my WOZ, it fires a ball (something new), and then the winkie guard solenoid starts firing randomly and rapidly. It eventually stops. I can play the game and get the ball into the castle VUK and hen nothing happens. The game does not recognize the ball is in the VUK and it goes into ball hunt mode and eventually ejects the ball up to the castle play field. Not sure what us happening.
I did do some work on the game. I added the Mezelmods state fare led and throne room fire pots the night before without issue. Everything worked fine.
The next day (Sunday), I replaced the trooper with the 75th anniversary topper and installed cliffy shooter lane protectors. After that, I had the issue.
I disconnected the topper and removed the shooter lane protector (thought it might be causing a grounding issue),I also disconnected the other mods but I still had the problem.
My guess is coincidence or I bumped something.
I checked the winkie guard solenoid connectors and made sure nothing is binding.
Checking here to see if anyone else had a similar issue.
Thanks for your advice.
Rich
#2 9 years ago
2 separate problems. First, for the drop target, it may not be 'catching' in the up position, so the game has to push it up a few times to get it to stay up. Check that the target is in the middle of the rectangular playfield hole, and not rubbing against one side when it's up. You can slightly bend the entire drop target/coil bracket to align it better--pull the bracket forward or push it back--slightly--as needed. using moderate force. it may take just a tiny tweak to get the right clearance.
For the VUK, did you do a switch test? Make sure the switch registers when a ball rolls into the saucer. (A magnetic probe helps pull the ball back out while testing!) If the switch doesn't register, check the connectors, maybe bend the leaf part up a bit to make it more sensitive.
#3 9 years ago
Drop target - please check that the switch is on tight.
VUK has optos, check for loose wires / connectors.
#4 9 years ago
Thanks for the advice.
I checked to see that the drop target was not hanging up and that the mechanism seems to be working.
I ran the switch test, not sure i did it correctly, but I did not notice any changed when I put a ball in the winkie guard vuk.
I did not see any loose wires. The one on the winkie guard is solidly planted. I even crimped it a bit for a better connection. The wires to the VUK optos are soldered and all looks tight.
I don't think the opto in the castle vuk is working because when I put a ball in there during game play, nothing happened.
Any other suggestions. Strange thing is, it was working good when I put the electrical mods were in, but when I swapped the topper and added a couple plastic protectors I started having this problem.
Rich
#5 9 years ago
The vuk opto wires run from the optos to the I/O board. I'd start looking for a wire that came out of a connector type scenario.
#6 9 years ago
What did the switch on the drop target do in test ?
#7 9 years ago
So this is wierd. When I pulled the playfield out so it rested on the support bars a little. The VUK switched registered the ball (turned from pale green to bright green) and ejected it, both in the winkie and castle VUK's. When i rest the playfield on the edge of the plywood, or fully inserted, they do not register the ball. So, I conclude the optos are working, but something else is going on.
#8 9 years ago
Quoted from RJL:
Like a loose connection ?
#9 9 years ago
if that's what's happening, then something is definately loose - the cables are moving with the playfield a little...... I'd lift the playfield all the way up and check/move stuff.
#10 9 years ago
I have had a similar experience.
After doing some repairs like removing the castle pf, adding some mezelmods etc. I plugged a wire or 2 in the wrong location, or left 1 unplugged.
The game did exactly as you described, went bat-sh*t crazy. Castle vuk endless popping or not registering, winkie endless cycling, ball launch in start-up etc.
I had to go over every single connector (power and data), took about 45 mins until I found the problem.
I've actually had this happen a few times (evidently rye whiskey and pinball repair do not go hand in hand).
I'm confident this might be your case.
It didn't seem to harm the game in any way, just confused the hell out of the computer.
#11 9 years ago
I found a broken connection to a switch on the left ramp just past the haunted forest trees. Two green wires connected to a tap on a switch that had broken off. I will solder that first chance I get. It is not near the winkie, but I wonder if that is causing the computer to get confused. I don't think I would have found it if I was not half into a bottle of wine. I would do it tonight, but for the wine. Stay tuned. I appreciate the advice.
Thanks,
Rich
#12 9 years ago
It's working! That broken connection was the problem. The wiring harness to that switch is very close to the edge of the playfield. The connection must have been moving every time I had the the playfield up until the tab on the end of the middle leaf of the switch eventually sheared off. Even though this switch was not near the winkie drop target, it appears to have confused the computer as was suggested. Thanks to all for your advice. Much appreciated.
Rich
$ 199.00
Pixels Arcade Games
12,000 (OBO)
Tacoma, WA
$ 225.00
Pinball Mod Co.
8,600
$ 159.00
Pixels Arcade Games
$ 95.00
Pinball Mod Co.
Pinball Mod Co.
$ 85.99
$ 69.00
Pixels Arcade Games
$ 43.00
The MOD Couple
$ 16.95
Precision Pinball prod.
RavSpec
$ 91.00
$ 259.99
10,000 (OBO)
San Jose, CA
$ 345.00
Pinball Mod Co.
$ 49.99
