(Topic ID: 204505)
WoZ Volume Control Board
By RandyV
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by Nokoro
#1 3 years ago
Just curious if anyone has had the volume control board on their WoZ die. I was playing the other night with headphones plugged in and stopped to eat dinner. I left the game on. When I came back (after 30 minutes or so) the volume control was dead and I had no sound through the main speakers. Looks like the board just up and died for no real reason. I disabled the volume control board and sound came back through the main speakers.
Probably just a fluke and I'll buy another board from JJP, but I am curious if anyone else has had this happen or if there's a common component on the board that fails and can be easily repaired.
#2 3 years ago
In 4 1/2 years, yours is the first one in a long time I've run into. Thinking back, I can only recall one or two others.
#3 3 years ago
Quoted from LTG:
Thanks Lloyd. I always knew I was special. LOL!
#4 3 years ago
Maybe the headphones died?
#5 3 years ago
My volume is going in and out. It was intermittent at first and now is constant. The volume is low, especially the speech. I have a ticket in to JJP asking what to check. I already reseated all audio cables I believe. Can you tell me how to disable the board so I can try that?
#6 3 years ago
There is a tiny switch on the board inside the coin door.
#7 3 years ago
Heard back from JJP about my issue. It was the noise filter that went bad.
#8 3 years ago
Quoted from mountaingamer:
All the lights on the volume board are dead so the board is definitely bad. Ordered a new one from Paul this morning...
#9 3 years ago
Quoted from Nokoro:
Had this issue as well and found it to be a connector inside the CPU cut a zip tie or two to get more slack and my problem went away. Fyi just in case the filter is not actually the issue
3 months later
#10 3 years ago
Quoted from Nokoro:
I’m experiencing this currently, more frequent than before. During a game the music & speech go faint, sub seems out too, then comes back on and later will go off again,
Any suggestions as to this ? Boards, cable or filter?
#11 3 years ago
Quoted from steigerpijp:
I would bypass the filter and see if that fixes it. It is easy to do, and if it works, just leave the filter bypassed. That's what worked for me.
