To my surprise, after only 250 plays or so my Throne Room hole has severely chipped. I do not have a Cliffy on it but the chips did not start where a Cliffy would protect the hole. Anyone else's look like this? I'm adding up a few layers of clear to stop any wear hopefully, then adding mylar as best as I can around the hole once the clear cures enough.
While performing the minor teardown to clear the area around the hole for repair, I found that I cannot remove the plastic with Toto and the Wizard on it without using a pin extractor! The wires are on quick disconnects beneath the playfield but they are too large to fit through the hole. WTF? What's the point of the connectors if you can't remove the wires from the playfield?
