(Topic ID: 178916)
WOZ read error?
By patrickvc
2 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by Pinballomatic
#1 2 years ago
Machine has been fine. Now this on a black screen at startup
#2 2 years ago
Can't see what you're talking about but if machine won't turn monitor driver boards are known to go bad. You can
remove backglass and switch off monitor by tiny switch. Machine will boot now even if bad monitor.
#3 2 years ago
With the power off, flip up playfield, remove lid of chassis box, solid state drive is mounted on right hand wall near the front (closest to the player). With power off, you do not need to unscrew the hard drive, just slide back the power connector and reseat, slide back the data cable and reseat. Follow data cable to the corner of the motherboard, lift off and reseat in case there is any static or crap in there. Power on machine, see if it boots now.
