(Topic ID: 189525)
Woz - problem game stuck after Dorothy captured
By jimy_speedt
6 years ago
  • 17 posts
  • 8 Pinsiders participating
  • Latest reply 6 years ago by PinMonk
#1 6 years ago
Hi,
Since 2 days ago, when the ball is captured by monkey lift assembly, it rests on the castle home switch, then I get the video showing Dorothy captured, then it goes back to the standard 4 parts screen, and nothing moves afterwards. No ball is ejected from the through to the shooter lane. If I press the flipper buttons then the game puts a new ball in play. In the past, a new ball was automatically put in play after the video sequence is finished.
Also when the game is over, or if I switch off/switch on the machine, the ball locked in the Monkey castle is not released. After a while, the game triggers all the coils and the ball captured is released.
In test mode, the switch 79 Monkey castle home is activated (green) after the ball is captured. This switch is not the problem, and I do not know what can be wrong.
Can anyone help me please ?
Thank you
#2 6 years ago
Did you check the settings for empty ball lock when game is over? That's for the game over balls not being released, the other is there a setting for an additional balls to to be put into play until ready by hitting a button? Have you updated the game recently since it was working fine prior? or did you do a factory reset?
#3 6 years ago
Hi,
thanks for you reply. I just noticed that there was an issue with the plumb tilt. Now the ball is released at new game. But the problem of game stuck after ball captured is not solved. No I haven't updated the code as I received the game 1 month ago. It is version 6.10. I made a factory reset, but no change.
#4 6 years ago
I have the same problem...although it's a REALLY minor problem. What's happening is that the monkey isn't dropping the ball behind your castle door. Try it the next time the monkey captures your ball...look behind the door as you press both flippers. You'll see him drop the ball and that will cause another ball to be ejected into the shooter lane.
I haven't solved my problem because I haven't had time and it's more of an annoyance than a game-stopper. But when I asked about it a while back, it was said to be a magnet problem and I should try a piece of electrical tape on the monkey magnet. I did, but then the monkey couldn't grab the ball. Perhaps the balls are magnetized and need to be changed out...that's my next "fix." If that doesn't work, I'll contact JJP or post here.
#5 6 years ago
Quoted from beelzeboob:
Electrical is too thick. I think a friend of mine fixed this with a piece of scotch tape.
#6 6 years ago
Excellent point that I totally over looked or never thought about with WOZ, on that subject is there one place over another to buy balls of different quality that don't seem to magnetize or at least not so quickly that would cause these minor annoyances.
#7 6 years ago
Quoted from DeathHimself:
Well, the interesting thing is that I use the pinball life super shiny balls that aren't supposed to be subject to magnetization. That's what makes it strange in my case.
Quoted from imharrow:
Thanks! I'll try it again.
Somehow this thread turned into MY help thread.
#8 6 years ago
I just did electrical tape last night actually, and it worked great all night during a party. Seems to have worked on mine.
#9 6 years ago
They are not supposed to get magnetised but they do!
#10 6 years ago
Thank you for all these feedbacks. I ll try the tape and change the balls
#11 6 years ago
It took me a bit of time to properly understand the above. My problem is not that the monkey keeps the ball. It releases it normally behind the door, and the switch is activated. But then nothing happens were a few days ago everything was working fine.
#12 6 years ago
Any further idea ?
#13 6 years ago
Quoted from jimy_speedt:
Any further idea ?
Does the switch STAY activated? I had this issue where the ball wasn't keeping the switch activated when dropped behind the door. Put it in switch test mode and drop the ball in there and see if the switch stays closed while the ball is in there. Adjusting the switch solved the problem for me.
#14 6 years ago
Hi thanks. What I checked the switch matrix after the ball was released behind the door. On the playfield picture, the switch is marked as green .i.e. activated. but I will try dropping the ball manually in test mode, to see what happens
#15 6 years ago
Switch 79 is not the correct switch. The monkey castle home switch tells the game that the monkey has reached the upper left of its rail and should stop moving and release the ball.
You want to look at switch 72, castle ball lock. Check out page c-66 in the manual.
#16 6 years ago
Yes indeed ... my mistake. And yes a switch adjustment solves the problem.
#17 6 years ago
Glad you're fully functional again!
$ 29.99
Hardware
Classic Game Rooms
$ 85.99
Stephenson, VA
$ 49.99
$ 115.00
Pinball Mod Co.
Pinball Mod Co.
10,000 (Firm)
San Jose, CA
$ 259.99
$ 55.00
Pinball Mod Co.
$ 50.00
Duke Pinball
10,500
Warner Robins, GA
$ 69.00
Pixels Arcade Games
$ 29.00
Filament Printing
$ 199.00
Pixels Arcade Games
$ 345.00
Pinball Mod Co.
9,250
Mt Zion, IL
$ 18.00
Volcano Pinball
$ 159.00
Pixels Arcade Games
Pinball Photos LLC
$ 9,800.00
Pixels Arcade Games
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/woz-problem-game-stuck-after-dorothy-captured and we tried optimising it for printing. Some page elements may have been deliberately hidden.
