I'm having a strange problem with Woz.
The game seems to play fine, but I've had to replace fuse 710 three times in the past 2 days. It doesn't blow immediately so I'm trying to locate the problem. I can play for a quite awhile before the fuse blows.
I found a potential clue, but looking for some advice on how to troubleshoot (or fix) it.
Every coil under fuse 710 works in Coil test, even with the COIN DOOR OPEN. (This is not correct.)
Every other coil NOT in the 710 fuse circuit will only fire in test mode when the coin door is closed (correct operation. )
Does anyone have an idea how or why the coils in the 710 fuse circuit can fire in test with the coin door open?
I'm assuming if this issue is corrected, the fuse may stop from blowing intermittently.
